[ View Full Version Of This Page ]
1995 LT1 overheating-
All Forums » Corvette C4 Forum » 1995 LT1 overheating-
gem48
7/14/2007 10:33:53 PM
I have a 1995 LT1 coupe that overheats when stopped in traffic and outside temp exceeds 85. I have a new radiator and heater and recently had new thermostat installed by Mr Goodwrench local dealer. I aksed dealer to install lower thermostat and they refused, CA emissions law. Car still overheats to 230 before the fans kick in. Is this normal? I have noticed sporadic overflow from radiator. What else could cause this?
Thanks
Gene in San Jose
7/14/2007 11:45:36 PM
from my other replies on overheatin'...
Could be just a lotta' bug jam in the radiator - horseflies, mosquitos, lizards, deer, flounder, ya know...
Seriously, get a hose blowing through the fins...
Get a thermometer in the heat duct, early in the morning, warm motor, heat on, to make sure you got flow in the heat core. Then go from there...
Water pump, water flow, thermostat.
Here's your problem:
1) Your water pump is bad.
2) You have flow blockage.
3) The thermostat is bad (same as blockage).
Cold motor. Drain and recover your coolant. Put your garden hose in the coolant hose in one place. Disconnect the coolant hose in several OTHER places, ONE AT A TIME, to check for flow. Observe also for 'jam' of any sort.
YOU WILL NEED A FLOW SCHEMATIC FOR THIS, TO MAKE SURE IT'S COMING OUT WHERE IT SHOULD. A BLOCKAGE WILL MAKE IT COME OUT IN THE WRONG PLACE. I THINK HAYNES HAS IT.
Before puttin' back in your coolant, get the residual tap water out with a shop vac. You will afterward still have air in your system. If the TPI doesn't have a air bleed nipple, get on the highway, WITH HEAT ON!!! This should bring up the air. Check on a COLD motor.
If this fails, go to a radiator shop. They'll hit your pipes with a laser, and check for in-spec coolant temps to diagnose.
khaki1967
7/15/2007 8:14:37 PM
Six months of research and addressing the normal stuff ie. radiator flush, removal of debris, thermostat replacement WP check etc. I've talked with Corvette shops and compared with other C4s seems to be the norm. My fan kicks on at 228 and turns off at 217. Not much room for air flow with these cars are idling. I recall a previous post describing a kit that is available to turn fans on sooner. If you do a search on this forum, you will find much info on this subject but I'm convinced this is normal.
LeesVette
7/16/2007 4:53:46 AM
Your temps are normal............
7/16/2007 5:28:48 AM
Yes they are normal, gem. I 'cutted' n pasted into the wrong overheatin' thread here.
Blue Admiral
7/16/2007 8:11:31 AM
I have the same situation with my '95. The dealer and everyone that I have mentioned it to says that is normal temp. I don't get the coolant spill over though. I'd be sure to keep an eye on that.
86 Ironhead
7/17/2007 6:13:43 PM
quote:
ORIGINAL: gem48
Thanks
Gene in San Jose
Hypertech has a chip and 180 therostat that will make you and your motor much happer.  We people in arizona all use them. They are legal in California, but might be touchy at a chevy dealer.
Look for a real corvette mechanic in your area that can setup your car (Tune-up).  It will still pass emissions.
Cris4
7/19/2007 4:36:18 PM
Have same problem with my '95 LT1.
I pull over at 230 and simply cruise a parking lot if it is all I can find. Just moving at a slow speed seems to cool it quickly.
How hot can we let them get before they blow?
Anyone know?
Cris4
Viscount
7/19/2007 5:28:25 PM
quote:
ORIGINAL: Cris4
Anyone know?
Cris4
On a 95 the fans turn on "lo" at 228*. They go to "Hi" at 238* The fans run in concert, Those temps are normal.  The digital temp is  more accurate than the analog. Check your owners manual. It tells how to interpet the analog readout which is graduated in a way that can be a little confusing.
84corvetteC4
8/5/2007 7:38:08 PM
as bad as it sounds 230* is what they run at and thats all there is too it, you can have it re-chipped to attain lower temps by making your cooling fans come on at a lower temp than 228* with a combo of a lower temp themostat but other than that just drive it
LeesVette
8/6/2007 5:06:19 AM
quote:
ORIGINAL: Cris4
Anyone know?
Cris4
At 260 degrees you had better shut it down.  It won't last much beyond that point for an extended amount of time without cracking and/or warping major components.
Related Threads
Return to the Corvette Forums home page - Archive Home
