Finally, A Detailing Kit That Has EVERYTHING You Need!!!
Old 06-22-2015, 11:53 AM
PinnacleWax's Avatar
Former Sponsor
Default Finally, A Detailing Kit That Has EVERYTHING You Need!!!
Everything you need to clean and protect your investment inside and out!
Caring for your vehicle is easy when you have the right products and tools. To make your selection easier, we’ve assembled this complete kit for interior and exterior surface care. With the Pinnacle Total Interior/ Exterior Detailing Kit, your vehicle will look like it belongs on the concours circuit and you’ll look like the detailing extraordinaire you really are.
Our super deluxe Pinnacle Total Interior/ Exterior Detailing Kit includes:
8 oz. Pinnacle Souverän™ Paste Wax
Souverän™ is a hand-poured wax designed to produce the deepest wet-look shine possible in a paste wax. It is a special blend of Brazilian Ivory Carnauba and natural oils which produces tremendous depth and richness. The easy-on, easy-off formula makes waxing your vehicle as enjoyable as it is beneficial.
16 oz. Bodywork Shampoo
Pinnacle Bodywork Shampoo has the smooth, silky feel and aroma of a luxury body gel. As you wash, natural coconut oils attach to surface dirt. These oils act as a lubricant. Sand and abrasive grit slide off in the rinse water without scratching the surface. New Improved Formula! Pinnacle Bodywork Shampoo now contains Tuff Suds ®.New technology uses cleaners suspended in the bubble's walls to scour away tough dirt and grime. Most important, the suds last! No more flat suds water before the job is done!
16 oz. Paintwork Cleansing Lotion
Applied prior to waxing, Paintwork Cleansing Lotion will restore and preserve your car’s original beauty using d-Limonene, a natural cleaner made from the rind of oranges, along with lemon oil, natural clays and sea kelp to polish without abrasives.
16 oz. Crystal Mist Detail Spray
Use Crystal Mist after washing or anytime to bring back that just-waxed shimmer. Crystal Mist is a blend of super-refined, brazilian Ivory Carnauba, conditioning oils, and crystalline polymers. More than a quick detailer, this spray carnauba will add an additional layer of glossy protection.
16 oz. Leather & Vinyl Cleaner
This is a pure cleaner without any silicone oils, petroleum solvents or gloss agents. Water-based surfactants and non-alkaline cleaning agents penetrate deep into every pore to gently lift out dirt, grease and oils. The toughest stains wipe away leaving only a fresh lemon scent. Pinnacle Leather & Vinyl Cleaner has a pH-neutral rating of 7 to match the pH range of leather itself.
16 oz. Leather Conditioner
Pinnacle Leather Conditioner nourishes leather with a rich formula of lanolin and natural oils.These oils quickly absorb into the hide leaving a non-greasy, satin finish that actually repels dirt and moisture. A subtle fragrance compliments the leather’s natural aroma.
16 oz. Vinyl and Rubber Protectant
Pinnacle Vinyl & Rubber Protectant beautifies and protects your car’s dash, vinyl seats, and door facings. Our blends of natural and modern ingredients restore the natural sheen of vinyl without that artificial plastic look. Surfaces are enhanced to a non-greasy, satin luster. Conditioning oils of vanilla and banana provide a fresh, natural fragrance.
16 oz. Black Onyx Tire Gel
Black Onyx Tire Gel is a VOC compliant formula containing no alcohols, and no petroleum distillates. One application will give tires a deep, black enhanced surface that can only be described as a rich onyx. It protects and beautifies–putting a virtual barrier between your tires and the elements, combating the effects of road and weather conditions. Includes one Flex Foam Tire Dressing Applicator.
16 oz. Advanced Wheel Cleaner Concentrate
Pinnacle Advanced Wheel Cleaner Concentrate is a concentrated wheel cleaner that is designed to annihilate pesky brake-dust and oily road grime. Formulated using the latest cleaning technology, Pinnacle Advanced Wheel Cleaner Concentrate forgoes caustic acids, butyl ethers, and other harsh detergents that do more harm than good. Pinnacle Advanced Wheel Cleaner Concentrate changes colors as it dissolves brake dust and the concentrated formula can be diluted up to 1:3 with water for maintenance cleaning.
Pinnacle Professional Wash Bucket with Grit Guard
This 5 gallon bucket has an added benefit. Inside is the Grit Guard Insert, a raised radial grid that keeps dirt at the bottom of the bucket where it’s less likely to end up back on your vehicle. The Grit Guard Insert works by stabilizing the water to keep dirt from rising once it has settled to the bottom. The wash water and your mitt stay cleaner!
Lake Country Wash Wedge
The Lake Country Wash Wedge holds a ton of soapy water, providing ample lubrication for the sponge to glide effortlessly across the surface. The cross-cut and slotted grooves conform to sharp body lines and creases, ensuring every square inch of your vehicle is cleaned. Use a separate Wash Wedge to clean intricately designed wheels – you’ll wonder how you ever washed your vehicle without it!
Speed Master Wheel Brush
The Speed Master Wheel Brush is the most advanced wheel detailing brush today! Built for quick, effective cleaning of all wheels, the Speed Master Wheel Brush has a state-of-the-art design that cleans any wheel surface and any wheel design – without scratching! Brake dust beware! There's nowhere to hide from the Speed Master Wheel Brush.
The Supreme Guzzler Waffle Weave By Cobra, 20 x 40 inches
The Supreme Guzzler is 20% thicker than the original towel to give it an even greater capacity for moisture. At approximately 5.5 square feet, this waffle weave towel can dry most small cars without being rung out once! As you may well know, microfiber is made of two synthetic fibers: polyester and polyamide. Polyester accounts for the towel’s durability and polishing properties while polyamide is silky soft. The plush 80/20 weave of the two fibers allow the towel to hold a tremendous amount of water; seven times its own weight!
3 Gold Plush Jr. Microfiber Towels, 16 x 16 inches
The Gold Plush Jr. Microfiber Towel is made of incredibly soft and plush microfiber in a handy 16 x 16 inch size. It's perfect for quick detailing and pampers every surface it touches. The Gold Plush Jr. Microfiber Towel measures 16 x 16 inches and features an outstanding 70/30 blend of polyester and polyamide. The microfiber’s weight is 380 g/m², making one very soft, thick towel! It's perfect for buffing.
2 Foam Wax Applicator Pads
The foam wax applicator can apply any wax evenly without creating any swirl marks. It’s absorbent in order to catch drips or runs, and it applies a perfect, even coat of paste waxes and polishes.
4 Microfiber Applicator Pads (color may vary)
Use microfiber applicator pads for applying pre-wax cleaners, polish, dash and tire dressings. They will apply even coats and catch drips and runs. Washable and reusable. Color may vary.
Give your vehicle the ultimate care with the Pinnacle Total Interior/Exterior Detailing Kit!
Kit includes:
8 oz. Pinnacle Souverän™ Wax
16 oz. Pinnacle Bodywork Shampoo
16 oz. Pinnacle Paintwork Cleansing Lotion
16 oz. Pinnacle Crystal Mist Detail Spray
16 oz. Pinnacle Leather & Vinyl Cleaner
16 oz. Pinnacle Leather Conditioner
16 oz. Pinnacle Vinyl and Rubber Protectant
CLICK HERE to get your Pinnacle Total Interior/ Exterior Detailing Kit NOW!
DeeVeeEight
04-21-2008 01:04 AM
HawaiianCorvette
12-12-2007 10:23 AM
Pecemkr
10-12-2006 06:37 AM
billennium
09-11-2006 09:20 AM
Danase
01-03-2006 10:23 AM
Quick Reply: Finally, A Detailing Kit That Has EVERYTHING You Need!!!
