1967 Gas Tank Removal
Old 07-07-2008, 06:20 PM
reeltales's Avatar
Default 1967 Gas Tank Removal
I have just bought a 67 convertable. I need to replace the fuel tank. Can this be removed without removing the body?
Old 07-07-2008, 08:16 PM
78buckshot's Avatar
Default RE: 1967 Gas Tank Removal
Welcome to the best Vette forum reeltales, I can't say for certain on the mid-year cars if you can drop the tank, I assume you can. Mine is a '78 and like all of the C3's, the tank comes out from the bottom. Please be patient, someone here will give you the answer.
Old 07-07-2008, 08:20 PM
78buckshot's Avatar
Oh yah, I'd like to add that the frame and most of the rolling stock is the same from 1963 thru 1982, so I don't think the gas tank mounting will be any different in those years.
Old 07-08-2008, 05:52 AM
reeltales's Avatar
I have removed the crossmember that is below the tank and taken the nuts off of the tank straps. The tank will move around but appears to be too tight to just drop out the bottom. I do not want to try to force it out until I know for sure it will come out. There may be a trick to getting it out.
Old 09-12-2008, 09:45 PM
you remove straps holding tank and then you have to tilt up the end (toward front of car I think) and wiggle it out, it seems impossible but it WILL come out, done it several times on my 67 and in fact plan to do it soon. good luck.
Old 09-16-2008, 08:11 PM
reeltales's Avatar
I was able to remove the tank. Now to order a new one. Despite the 14 year old gas that was left in the filter and lines, I was able to get the car running with the help of a new distributor.
old mac
06-29-2008 11:23 AM
kevncorvette61
10-27-2007 06:59 PM
herms77
07-31-2006 12:28 PM
chem1
04-23-2006 08:51 AM
john
09-03-2005 03:48 PM
Quick Reply: 1967 Gas Tank Removal
