61 removal of gas sending unit
Old 04-11-2008, 05:42 PM
60n61 Man's Avatar
Default 61 removal of gas sending unit
Was wondering if anyone can tell me if in order to replace the gas tank sending unit on a 61, do you drop the tank from below, or is there an enterance from the trunk area?
Thanks,
B
Old 11-29-2015, 01:38 PM
SnakeQ's Avatar
You remove the gas tank cover under the soft top deck lid. The sending unit is accessed from the top of the tank. The most time consuming task is removing the screws that secure the tank cover.
Old 06-12-2017, 03:33 PM
Greblo's Avatar
Snake's correct that it is very easy. If I recall, both the gas tank cover and the sending unit cover have a bead of sealer (caulk) around them to keep the fumes out and seal everything. The caulk is available at all the corvette specialty websites.
60n61 Man
04-10-2008 08:54 PM
KenHorse
05-15-2007 08:07 PM
littleRedCoupe
10-16-2006 09:35 AM
FLbTLINE
09-10-2005 01:22 AM
espo 89
06-13-2005 08:48 PM
Quick Reply: 61 removal of gas sending unit
