which model
Old 05-05-2008, 08:42 AM
kruser's Avatar
Default which model
Can someone tell me how to tell the difference between a early model 77 corvette and a late model 77 corvette? Thanks
kruser
Old 05-05-2008, 03:46 PM
pg's Avatar
pg is offline
Default RE: which model
Hi kruser, I'm not sure but here's some info on the 77 Http://100megsfree4.com/corvette/1970/vet77.htm PG.
Old 05-05-2008, 10:29 PM
Here's some more tidbits: http://www.vettefacts.com/C3/1977.aspx
Old 05-05-2008, 11:51 PM
The serial(vin) number should give you some Idea as to where in the production run is falls. Cain't remember but do these cars have a "manufacture date" on the RPO sticker? Cheers
Old 05-06-2008, 04:50 AM
78buckshot's Avatar
The sticker on the driver's door tells mine was built in October 1977, mine is a 1978 model. A couple of small items are carry-over from '77. When I ran the VIN through another site, it came up as a build date of October 3rd, 1977. I don't know the exact date or difference between the early and late '77.
Old 05-06-2008, 10:00 AM
stlvet's Avatar
I have '76 and there are some slight changes from early to late production on that year as well. Going by a part description in a catalog, one difference on the '77 is the engine coolant recovery tank. The tank for an early '77 will haveboth hoses attached to the cap, one for overflow and one tank to radiator hose. A '77 late tank has a tube connection for the tank to radiator hose. This tubeis part of the tank itself, attaching on the bottom of the tank. If your car still has the original tank this might be a clue.
Old 05-08-2008, 08:56 AM
Texas Jim's Avatar
The "Stingray" was gone for 1977 due to Bill Mitchell retiring-he was responsible for the original "Stingray" design. With no more "Stingray" on the side of the front fenders, that panel was blank for early 1977 production, (for exactly how long this took place, it doesn't say,) then the "crossed flag" to match the front and rear emblems was added to the sides.
C3 Starship
12-20-2006 08:37 PM
JBurer
08-10-2006 03:45 AM
bertsbassbox
06-01-2006 09:21 AM
cat1055man
03-21-2006 10:47 PM
whohidjohn
08-02-2005 02:24 AM
Quick Reply: which model
