Radiator
Old 09-24-2015, 11:13 PM
AviviElectric's Avatar
Default Radiator
Just purchased a 1979 corvette and the radiator is leaking. I met a mechanic and he suggested a spectra cu718 brass radiator. I am far from a gear head so I can use some advice.
Old 09-27-2015, 11:01 PM
If it fits w/o any mods and is a four tube core, then should be fine. Make sure the inlet and outlet are the same so stock upper and lower hoses will fit. Also if auto trans, then a cooler is req'd in the radiator.
Old 09-29-2015, 04:09 AM
Thank you for responding, well it's too late theY installed and also they modified said this rad is a lot bigger then old one. I also don't understand about auto trans. My car is automatic so your telling me I need a cooler in radiator. My initial response about bigger rad was it will keep car cooler. And I joined forum the day I dropped car off. So I read your post then went to shop and it was too late he said they modified to get it in. Before I do anything I will ask here first.
Old 09-29-2015, 08:10 PM
There should be two lines about 3/8 inch diameter running from the transmission to one of the tanks on the side of the radiator. That transmission cooler is inside the radiator.
I would check and see what modifications they made to get it to fit. Any modifications will void the manufacturer's warranty. If you have an air conditioned car, they may of had to remove the condenser to get the radiator in. Of course if they modified the radiator such that they didn't have to remove the condenser, then that's a different story.
Marty73
12-31-2006 01:30 AM
Raupleminze454
10-19-2006 07:05 PM
wrwalke
09-11-2006 02:12 PM
Bagpipingjake
08-21-2006 11:20 PM
stang2x
11-15-2005 10:38 PM
Quick Reply: Radiator
