1996 Corvette LT1 Coupe
Hi, I have been beating my head against the wall trying to find the answer to a question. On my 96 I have an ASR module on the drivers side. It's a black box and under it is a cam that houses the throttle cable to the throttle body, another cable running to the cruise control...looks like a large canister near the driver side door and the third cable runse to the gas peddle. I only see an adjustment on the cable running to the trottle body and the other two cable have no adjustment on them. So, now my question is this..do I have to adjust the cable to the throttle body if I removed the throttle body? I didn't remove the cable from the asr module I only removed the cable from the TB. I cannot find the answer to this question anywhere and was hoping someone out there would have the answer. If I do have to adjust it what is the procedure? I really hope someone can help me. Thank you so much.
Dale
Dale
Thank you for the reply. Since I posted the thread I have put the TB back on and it seems to be fine. I don't have any slack in the cable. Everything seems to be working correctly when I press the gas pedal to the floor the TB opens complety. I am guessing that is correct. I didn't remove any cables from the ASR unit, so it seems what you said in your post is totally correct. If you don't mind I would like to ask you a favor and take a picture of what I would need to adjust in the event I ever have to remove or replace the cable going to the TB. I hope I'm not asking to much. You have set my mind at ease with your reply. Thank you so much. Question: Do you have a 96 as well? Thanks again...Dale
