3 questions on 1985 4+3 manual
Old 10-31-2006, 03:48 PM
mercedes84black's Avatar
Default 3 questions on 1985 4+3 manual
1. my 1985, when at operating temp. sometimes the starter won't turn over, after sitting for 10-20 minutes she turns over fine. i know my clutch needs some adjusting, could it be the clutch or the starter needing replacement. 2. my tail light fuse keeps blowing, as soon as i put it in it blows. i know there's a short but which way do the wires run. passenger side fuse box to light switch to rear tail lights, please verify. 3. my 4+3 shifts fine 1st thru 4th but in reverse she will hardly move. how do you adjust the clutch linkage to correct this issue. any info greatly appreciated
Old 10-31-2006, 03:53 PM
Default RE: 3 questions on 1985 4+3 manual
Your #1 issue mentioned *might* be due to a bad starter solenoid. I unfortunately don't know about your other 2 questions, but I am 1000% confident one of our fearless tech's will be along shortly to help you out there.
Old 11-01-2006, 08:45 AM
i'd appreciate it if a little more info on this, especially the clutch and/or linkage adjustment. thanx
Old 12-05-2006, 10:54 AM
On the starter problem, your culprit is the clutch safety switch, I had the same problem. What I did, I just bypassed the switch with a wire jumperin the plug.
Old 12-05-2006, 04:12 PM
you hard starting when warm problem might also be a bad ground. you might consider taking the ground off and cleaning the ends or replacing the cable(s)
Old 12-06-2006, 03:10 PM
About your taillights...check the wires at the bulb receptacle, there might be a wire strand touching the other wire, thereby shorting it.
rm1sner
04-05-2012 09:50 PM
alchemy
09-25-2010 07:36 AM
xlwhellraiser
07-22-2006 03:34 AM
toroguy
04-01-2006 01:35 AM
vettey
01-21-2006 02:25 AM
Quick Reply: 3 questions on 1985 4+3 manual
