instrument panel lights .. replace 1987
Old 02-18-2006, 03:49 AM
JC's Avatar
JC
JC is offline
Default instrument panel lights .. replace 1987
The right side of my 87 inst panel lights are out,, all guages work fine just cant see them at night.. How much is involved in changing bulbscan I get them from under dash or do I remove inst panel from front
Old 02-18-2006, 12:56 PM
Default RE: instrument panel lights .. replace 1987
I completely rebuilt my display unit for my 84, you can use #94 bulbs that you get any any auto supply store, the bulbs that are in the display are twist lock bulbs that are very expensive, the #94 bulbs are a bayonet base with wire contacts, I solder the bulbs right to the copper landings on the pc board. taking the unit apart takes a littel while. but it's worth the savings, by the way if your display goes intermittent, you might have to resolder all the connections on the small power supply board
Old 02-19-2006, 11:04 AM
Go up to the thread titled"87 vette. He also inquired about the same problem. I addressed it there. It's not that hard to do.
good luck with it.
Old 02-23-2006, 08:39 PM
as an experienced electronic tech, i recommend this website, it gives you a step by step repair proceedure for the instrument panel. http://batee.com/corvette/dcrg/repair.htm
POLO GREEN 90
11-26-2006 10:37 AM
JC
02-26-2006 05:30 PM
JC
02-17-2006 04:45 PM
Bagpipingjake
12-04-2005 08:50 PM
oldtvman
06-01-2005 07:35 PM
Quick Reply: instrument panel lights .. replace 1987
