Considering differential swap
I have a stock 1989 convertible with 2.59 gears, auto trans. I am considering a numerically higher differential swap. It looks like factory options would have included 3.07 and 3.54. I drive the car mainly in town, very little open road. What kind of complications should I expect? What ratio would you recommend?
Welcome to the forum to you both.
Assuming the housings are the same for both gear sets, shouldn't be any problems. Be sure you get the gears set up by someone that knows what they are doing. Not a DIY job w/o the proper tools and knowledge.
Thanks for the greetings. I'm looking to trade my complete 3.07 diff assembly for a 2.59 or 2.73 so that the gears will not have to be reset. I'm aware that the speedo/odo will need correction. Does anyone know if the correction is done with the computer or by a gear change at the speed sensor?
d1 guy
10-25-2007 09:08 AM
