Dome lights will not shut off
#13
RE: Dome lights will not shut off
ORIGINAL: mech259
I'm assuming yours is a 93 from another post. Here is a wiring diagram for a 93 interior coupe. I suspect your problem is in the central timer module, but without a Tech 2 scanner to check it , []
You still think it could be the timer module? Is the timer module's clockintegral with the computer, or is it a dedicated clock itself?
#14
ORIGINAL: mech259
Big help as always[sm=icon_cheers.gif]
#15
Whereare the (timer module?) and the ccm located? Also am I to assume correctly that the central control modlue is the same as the body control computer on this vechile. Looking at the diagram the only things controllinginterior lightsare one switches, two adiode module, and three a ccm. The diodes are fine the switches are fine so I'm guessing the ccm is not. Or is the ccm controled by a body control computer,timer modulesome other relay or switch that is not on this diagram.
#16
ORIGINAL: Paul Spickard
the car is a 93
Thanks we'll see if this gets me anywhere. Were on the car can I find the ccm?
the car is a 93
#18
Well guys I thank all of you. It seems for now the problem is solved. I think th problem was in the dimmer switch on the the dash. I've replaced it and everything seems to be fine. Feel kinda foolish to be honest .
#20
simple solution (and general good idea for storage, and anti theft) is install an easy to get to but hidden kill switch. Now, this cures the symptom, not the problem, but they can come in handy when you are traveling as well. (hotel parking lots anyone?)
