L98 vs. LT1
Old 02-19-2007, 10:53 AM
C4Explosives's Avatar
Default L98 vs. LT1
I always thought the LT1 engine was more powerful than the L98 engine on the 91 corvette I just bought. According to a web site which compared factory stock 0-60 times and 1/4 mile times, they are the same.Both get 0-60 in 5.3 and 13.9 for the 1/4 mile. Which engine is better?
Old 02-19-2007, 01:49 PM
JoeVetteman's Avatar
Default RE: L98 vs. LT1
Hello,my friend.They're both great engines,but the LT-1 has the advantage of less weight,more horsepower,and better fuel economy.It also has a few newer details than the L-98,such as reverse-flow cooling,the Opti-Spark,and so on.But they're both fairly easy to modify and work on if you get the right parts for them.The fastest I've seen an L-98 car go to 60 is 5.1 secs.,the fastest LT-1 was 4.9.In the quarter I believe the LT-1 is in the low to mid 13's while the L-98 was a high 13 to low 14 second car.Hope you enjoy your Vette!!
Old 02-19-2007, 10:34 PM
LeesVette's Avatar
The L98 has more torque and might get an LT-1 out of the hole but it will run out of breath while the LT-1 has longer torque curve and will keep on breathing until it noses out the L98 in the last1/16th to 1/8thof a mile. BTW, Car and Driver tested the 1992 at 5.0 flat 0-60 and 13.6 in the 1/4 in their Dec. 1991 issue.
Old 02-20-2007, 12:03 PM
Guess I'm going to need some mods to keep up with the LT1 guys
Old 02-20-2007, 08:19 PM
I like the L-98 better. Off of take off which is what I go by "seat of the pants".....its fast. Stoplight races are fun.
Old 02-21-2007, 12:19 AM
I hear yah, that is where the funs is at. The power from the L98 is definitely enough for me, although I wonder what it would be like to put a supercharger on this thing. Wish I could afford it...it would cost as much as my car to put one of those things on.
Old 02-21-2007, 11:26 AM
LeesVette's Avatar
From what I hear, its tough to find a supercharger for a TPI set up.
Old 02-21-2007, 02:01 PM
http://www.rpmoutlet.com/aticorvettet.htm
I found several places on the internet that sells them. Looks like they run 4 to 6k. Can't seem to find one on ebay though.
Old 02-22-2007, 01:46 AM
ORIGINAL: C4Explosives
Miniram!
Old 02-22-2007, 09:53 PM
If you did put a supercharger on a L-98 would you not have to upgrade all ALL the parts. I mean the transmission is naturally weak from my understanding, the heads and exaust along with a cam are restrictive and then you will definatley need a new rearend. D44 I presume along with some havy gears and drag radials for street use? Im just guessing on this but can the stock L-98 take that much power with no mods or small amount of mods?
Quick Reply: L98 vs. LT1
