radio clock is lit up but radio will not turn on and antenna will not go up?
RE: radio clock is lit up but radio will not turn on and antenna will not go up?
I e-mailed you but, you seem to have checked the memory and radio fuses. More than likely, radio has bitten the dust. [8D]
If you replace it with another Bose, it's easy. There are replacements available, I put the Sony in, but you have to rewire everything as the Sony does not use the amped speaker setup as Bose does.
