Reverse Light Switch
Old 10-06-2007, 12:42 PM
jblack66's Avatar
Default Reverse Light Switch
I have a 1993 40AE...The reverse light and side back lights so not work...The fuse is fine...Has anyone replaced the reverse light switch...It's located on the upper left side of the manual transmission...I hate to have GM work on it...I suspect the switch must be faulty.
Old 10-06-2007, 06:19 PM
rshiver's Avatar
Default RE: Reverse Light Switch
Hi jblack, and welcome to the Corvette Forums.
It could possibly be the switch, unless some strange force of nature has blown all of the bulbs. Now, I'm not in any way insulting your intelligence, buthave you taken a bulb out and checked to see if they are blown, or if you have voltage to the lamp socket? It is possible for all of them to be blown, but not probable.
I wouldn't think it would be that hard of a job to replace the switch.It maybe harderto get to the switch, than it would be to replace it.
Let us know how it goes
Cheers
Old 10-06-2007, 06:33 PM
jblack66's Avatar
Thanks for the tip...I eventually crawled underneat and removed the connector from the reverse switch. Took a paper clip and closed the circuit...Voila!!!...The lights worked....now my problem is replacing the switch....any suggestions??...HELP!!!
vette'nfender
12-31-2013 06:52 PM
TripleBlackC5
10-15-2007 07:14 PM
cfptom
05-27-2007 08:00 AM
genuine1980
10-05-2006 03:33 PM
tdr1919
09-11-2006 12:21 AM
Quick Reply: Reverse Light Switch
