TPI maf system V TPI SPEED DENSITY
Hello,
Has anyone change a '87 vett from a MAF system to a Speed Density system, by adding a MAP sensor, Accel power process for a GM computer controlled engine and the use of CALMAP calibration software.
[IMG]local://upfiles/3690/444AD38EBFAF45C5B7243AB86E3D6F6D.jpg[/IMG]
RE: TPI maf system V TPI SPEED DENSITY
Im not sure if the pros outweigh the cons. The reason they changed back to MAF was because the MAP system isnt as accurate in measuring air coming in. You can get an adjustable MAF, or get different software to change the tables.
Later years, GM used speed density in production vehicles and it works fine. When they brought it back, they re-engineered the MAF hot wire sensor for more durability and accuracy. We have changed out a lot of the older MAF's, but very few of the newer ones. Even Ford tried the speed density setup along with Chrysler in early 90's. You shouldn't have any problems with it, just as long as you got the proper calibration for it.
1989 BLOWNCONV VETTE
06-17-2008 06:33 AM
GMRULZ
01-26-2006 10:43 PM
