fitting size for flex line to caliper. ?
Old 10-16-2016, 03:51 PM
RT PERFORMANCE's Avatar
Default fitting size for flex line to caliper. ?
Its one of those where I cant get a clear answer from anything I try to use as a reference. I think they are a 10mm banjo. But Im looking at adapters to use the ss flex lines I already have. A few companies sell a 1/4 npt to 10mm x 1.0 flare. And I think there are a couple other sizes available to. Is that what the 10mm banjo bolt thread is..? 1/4 npt..?
What I have is stock C5 calipers, and I want to use my 10mm male flare ss flex lines. And that is what is on the end. The flex line was originally for the Wilwood calipers with the 10mm male bubble flare. So the line is 10 mm female flare at both ends. I want to connect that to a stock C5 caliper. Any clear answer as to the caliper thread size or a link that list 10mm banjo adapter to 10mm male flare. I went every where and I couldnt find one at all.
Thx..RT
blackfire
12-28-2008 09:55 PM
StraightAxle
04-29-2007 12:28 PM
73Vette
08-26-2006 02:43 AM
maberry72
11-26-2005 09:53 AM
Quick Reply: fitting size for flex line to caliper. ?
