Power seat question
Old 10-05-2006, 08:17 AM
bluwolf's Avatar
Default Power seat question
Hi All,
The side bolsters on the driver's seat don't adjust in or out. The motor hums when pushing the button in both directions. But no movement. I don't suppose this is something simple, is it?
I think my biggest fear with this car is the electrical. Because what I know about electrical you can fit in a thimble and still have room left over.
Mike
Old 10-07-2006, 02:04 AM
Dave01's Avatar
Default RE: Power seat question
...from a similar post....
"You have to take out the seat but its not hard and take a close look at the hose going to the bolsters- you may be able to splice around the problem if you can see the cut--also check to see that the hose hasn't gotten compressed by some part of the seat mechanism--if so reroute it and tie it to some part of the seat so it won't it won't happen again. The other possibility is a leak in the bolsters themselves. they are simply bladders that hold air but I don't think both would leak at once so at least one side would inflate temporarily. Sounds like a hose problem to me. Good luck!"
Seat removal instructions:
http://www.vetteessentials.com/instr...er_change.html
Dave
Old 10-07-2006, 08:19 AM
bluwolf's Avatar
Thanks Dave.
I appreciate that. I did a search first. But I must not have phrased it right. Can I ask how/where you found it? Or is it just something you remembered.
Mike
Old 10-07-2006, 06:06 PM
Dave01's Avatar
Mike,
I didn't limit my search to one forum (in this case), although I DO have quite a bit of info saved from the 6 years I have been perusing Corvette-related forums.
Dave
Old 10-08-2006, 01:35 PM
ORIGINAL: Dave01
Dave
I love this link for the seat removal Dave, Thanks for posting it.
Old 10-09-2006, 12:07 AM
Dave01's Avatar
You're welcome, Rich!
Dave
mcgilles
02-12-2018 09:13 PM
barkerg
01-10-2008 03:29 PM
emd820
09-30-2007 10:44 PM
victory4jet
10-18-2006 12:39 AM
tonyrbp
07-23-2006 10:19 PM
Quick Reply: Power seat question
