Help!!!!!
Old 08-26-2014, 06:32 PM
EK vette's Avatar
Default Help!!!!!
OK I have a problem that I am sure someone can help with. This if for a 1993, long story short the car over heated really bad, none of the gages or lights told me this until the dash lit up like a Christmas tree. Anyway I had to replace the water pump, temp sender (both) and all of the hoses, now there is a very slight miss while it is running, maybe a plug or wire. But the real problem I am asking about is if the cap to the coolant reservoir is off, engine cold, and you start the car the coolant will gush out of the reservoir, it didn’t do that before it over heated. Could it be that a head gasket could have blew, or maybe a crack somewhere. It will also blow a very small amount of water out the exhaust pipes. Any guesses or information would be greatly appreciated.
Old 08-27-2014, 04:04 PM
It sounds like a head gasket or possibly even a cracked head to me. Are you getting bubbles out of the radiator after the initial gush out of water?
spanky01
07-23-2007 02:53 PM
mjrock62
06-08-2007 07:07 AM
74vetguy
05-18-2007 06:23 PM
aceosner1
05-16-2006 09:23 AM
sixspeed042
10-10-2005 02:00 PM
Quick Reply: Help!!!!!
