Time for new suspension?
Old 09-16-2014, 08:59 PM
ercriss's Avatar
Default Time for new suspension?
I purchased 1993 coupe last fall. The ride seems rough. I've assumed it just a stiff suspension. However, I'm beginning to wonder if its rough simply because its worn out. Any tips for determining a stiff susp. from a worn suspension?
It has a pair of yellow BilStein shocks on the front. any chance those are original with 181k miles on them?
Old 09-17-2014, 08:59 AM
A worn suspension will result in sloppy handling and irregular tire wear, not a rough ride.
Check the option codes sticker for the sport suspension option. I believe it was Z51 but not sure.
If the shocks are original, they are probably shot.
Old 09-17-2014, 05:06 PM
ercriss's Avatar
steering seems a little loose, especially when finding an irregular road surface on a gentle curve. I assumed bushings or maybe tie rod ends. I will check my sticker.
Old 09-17-2014, 05:13 PM
ercriss's Avatar
Here are the 1993 suspension option codes:
FE1 - Base suspension
FE3 - Sport suspension
FE7 - High performance suspension
I have base.
Old 09-17-2014, 10:17 PM
With that many miles, I suspect that the entire suspension will need to be checked.
Old 09-18-2014, 06:17 PM
ercriss's Avatar
ARE BilStein shocks original from factory?
Old 09-18-2014, 09:41 PM
I believe they are. I know that Corvettes have used Bilsteins.
Old 01-03-2015, 03:34 PM
Pitbul's Avatar
Old 01-04-2015, 12:39 AM
Without riding in it, it's hard to tell as one man's rough ride is another's road hugging, race ready ride.
You didn't say how many miles it has but you could check the shocks, ball joints, idler arm, tie rod ends, sway bar bushings, and end link grommets.
dar322
03-28-2008 12:11 PM
YZSoFast
06-05-2007 06:54 PM
Lee Willis
06-19-2006 09:40 PM
72 vette
05-10-2006 01:52 PM
farhan
10-10-2005 11:42 AM
Quick Reply: Time for new suspension?
