94 electric short?
Old 02-14-2014, 03:36 PM
braveheart3158's Avatar
Question 94 electric short?
SYMPTOMS
1-Battery dead
2-Interior lts stay on
3-Remove fuse for interior lights then horn stays on.
4- Remove fuse for horn.
5-Problem solved.
Have had the car for 2 years.
Before this latest problem:
1- From time to time the horn would not work if steering wheel was turned
2- Digital speedometer would stick time to time. Bang on dash wit fist would fix
3- Beep horn without ignition on, the security alrn goes on at the same time
Not sure if some or all of this stuff is related
I do have the shop manuals. Before I die into that, I was hoping someone would have some insight?
Thanks!
Old 02-15-2014, 04:34 AM
hcbph's Avatar
Default Problems
To me it sounds like you have a short in your wiring. You need an Ohm meter and you know which circuits you pulled the fuses in, that's where I'd start.
Old 02-17-2014, 06:33 AM
Thanks. Gonna wait or this weather to break a little. Right now the battery is not dying withy the 2 fuses pulled. I have a basic understanding of electric. But now sure how to start with the diagnosis. Use an ohm meter where? On the in and out terminals of the fuse holder?
Old 02-18-2014, 10:05 AM
ZFound battery dead yesterday even with the 2 fuse pulled, LHinterior lts and horn. So i removed the other hatch lts and any other interior lt fuses. Jumped the battery and let run.
Anyone know of a good auto electric guy on Long Island?
riley6riley
11-20-2007 07:21 AM
LT4Dave
11-22-2006 06:01 PM
rjensen
10-20-2006 01:43 PM
zo6r black widow
11-06-2005 09:15 AM
jeepxj
07-05-2005 07:09 AM
Quick Reply: 94 electric short?
