Corvette C6 Forum 2005+
Valve noise 2011 GS Coupe
Old 08-19-2014, 08:30 AM
Toonces's Avatar
Default Valve noise 2011 GS Coupe
Hi all. Just bought a 2011 GS Coupe with 11,000 miles on it. I just noticed over the last 2 weekends a definite "clicking noise" like a worn valve guide or valve clatter or injector noise coming from the engine. It happens either hot or cold but is most noticeable from 1600 RPM - 2200 RPM. I thought these engines were quiet in this range and there is no such noise at idle. I have just 2 weeks left on the 3/36 warranty and think I should get it checked out at the Chevy dealer. Thoughts? Any one else heard of this issue? Thanks!
Old 08-20-2014, 02:42 PM
Well I have not heard of this specific problem, I definitely would get it checked while it's still under warranty.
Old 09-03-2014, 10:36 PM
Toonces's Avatar
Default Follow up
I took the car to my local dealership. Both the service manager and the mechanic said there is definitely valve noise or other noise that is not normal, but they said they would not work on it as it is not affecting performance. If the noise does get worse they will then dig deeper into the engine. Hmmmm...
Old 09-03-2014, 10:54 PM
I'd either insist that they work on it or give me an extended warranty since yours is almost gone.
Bill X_R
04-24-2013 03:20 PM
paverman
06-03-2012 11:06 AM
pfg1
10-11-2010 03:54 PM
Patrick
Corvette C6 Z06
03-10-2010 10:15 AM
Quick Reply: Valve noise 2011 GS Coupe
