brake problem
Old 04-05-2008, 10:27 PM
cwb is offline
Default RE: brake problem
I've read in several places that the master cylinder on an ABS-vehicle CANNOT be bled of air without a scan tool.
Only a little air in the lines can, however...
  #12
Old 04-06-2008, 09:06 AM
The master can always be bled, it's the 4 wheel ABS valve that has to be bled on some applications with a Tech 2 scan tool, not all though.
  #13
Old 06-20-2014, 08:08 PM
Redwhisper's Avatar
I am having this same problem on a 91 Vette that I recently aquired. I have bleed the sysem 4 time with a vacume, I have to believe there is no air in the system. I have replaced the master cylinder, and check everywhere for leaks. How does the ABS valve cause this? Is there a way to eliminate the valve to see if the problem goes away? Mech259 suggests pinching off the rubber brake hoses will that show me it the ASB valve? Sadly I don't know what else it could be.
Todd TCE
08-25-2015 09:55 AM
vettemanrob
09-22-2006 09:59 PM
johnc
08-30-2006 06:25 PM
UncleJessie68
11-25-2005 01:38 AM
HeeBGB
10-30-2005 09:32 PM
Quick Reply: brake problem
