c5 LEAKing Targa...
Old 12-04-2008, 05:49 AM
Kevin98c5's Avatar
Default c5 LEAKing Targa...
So the rubber on my c5 targa is pretty good, no deterioration or anything, however it leaks in the front corners Driver and Passenger sides. Where the targa meets the windshields meets the side window. On the highway in the rain, it doesn't leak... however standing water does find it's way down.
Someone told me you can adjust the clips, and also pull the windows in?
How in the world would you pull the windows in?
And the rear solo clip of the targa isn't pulling it back much anyway. Would it need to pull it back more? It's very tight as it is w/ the front clips.
Thanks
~Kevin
Old 12-05-2008, 07:20 AM
2K2 C5's Avatar
Default RE: c5 LEAKing Targa...
maybe this will help...
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
Old 12-05-2008, 03:15 PM
Have you applied dielectric (silicone) grease to the rubber seals? If not, try this, ASAP!
Old 12-06-2008, 04:17 PM
Kevin98c5's Avatar
Thanks, but that's a convertible.
Doesn't really help.
Old 12-06-2008, 04:18 PM
Kevin98c5's Avatar
any write ups on her about that? Where to apply, how much etc?
That helps seal it from rain?!
Old 12-06-2008, 04:22 PM
Kevin98c5's Avatar
However, there were writeups on that c5 forum!
http://www.c5forum.com/cgi-bin/ultim...47.html#000002
http://www.c5forum.com/cgi-bin/ultim...48.html#000002
this adjusts the window tip in to seal better as well
10-07-2005 10:07 PM
farhan
10-07-2005 02:54 PM
blbcklt1_tb
07-31-2005 03:11 AM
pg0099
07-07-2005 11:05 PM
pg0099
06-17-2005 06:05 PM
Quick Reply: c5 LEAKing Targa...
