C6 won't start... HELP!
Old Dec 14, 2009 | 05:30 PM
sharrch's Avatar
Default C6 won't start... HELP!
Someone please assist me! This is the situation... The battery is not dead, already attempted to jump the car and it did not help. I am thinking it is something electrical, everything happens normal when I get in the car. I push the start button and the car clicks 3 times but it does not start. No clue what it could be... Plzzz help.
Old Dec 17, 2009 | 09:49 PM
88vetman's Avatar
try to see if the red hot wire with the fuseible link has not been damaged
Old Dec 18, 2009 | 10:29 PM
Where is the clicking coming from. Determining it's location may help with the diagnosis. Could be a bunch of stuff. How are the connections on the battery/starter? corroded/dirty? could be the starter is bad. could be something wrong with the "start button ?". I'd start with a good charge on the battery to be sure then clean and tighten all connections on the battery and starter. if that doesn't cure it remove the starter and have it checked. work your way back from the battery to the ignition switch.
Is the security system tied into the ignition on the C6's????
mattmont
May 25, 2015 12:34 PM
ktrixx
Sep 11, 2010 12:48 AM
Leader One
Aug 9, 2007 08:55 PM
djack
Jul 3, 2007 06:14 PM
Barry
Mar 12, 2006 03:05 AM
