TIRE PRESSURE MONITOR
Old May 27, 2006 | 01:23 PM
2001c5's Avatar
Default TIRE PRESSURE MONITOR
HI GUYS.. WHEN I BOUGHT MY 01 VETTE, THE MONITOR WOULD SHOW TIRE PRESSURE, NOW ALL IT SHOWS IS XXX, ANY IDEAS?
Old May 28, 2006 | 01:25 AM
Default RE: TIRE PRESSURE MONITOR
Look in your owners manual. It should explain how to do a relearn for the tire sensors. Hopefully, the sensors' batteries are not dead, but if every tire pressure readout displays XXXX, then the relearn may do the trick.
Old May 29, 2006 | 03:42 PM
2001c5's Avatar
OK DAVE, I LOOKED IN THE BOOK, NOTHING ABOUT RELEARN.
Old May 29, 2006 | 07:20 PM
2001c5's Avatar
dave, where are these batteries located?
Old May 30, 2006 | 01:26 AM
1) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old May 30, 2006 | 12:17 PM
2001c5's Avatar
ok dave, i will try it today.............i will let you know.
Old May 30, 2006 | 08:16 PM
2001c5's Avatar
DAVE, I GOT THE SYS FIXED, THANKS TO YOU. F SCHULTE
PS. I USED A MAGNETIC PARTS BOWL, IT WORKS WELL
Old May 31, 2006 | 12:43 AM
That's great to hear! Congrats!
Dave
Old May 31, 2006 | 12:44 PM
2001c5's Avatar
JUST FOR GRINS WHERE THE BATTERIES LOCATED?.................................
Old May 31, 2006 | 05:37 PM
I believe the sensor batteries are inside the sensors themselves. Fortunately, they tend to last many years.
dave
