Abnormal noise 1996 vette
Old Jul 14, 2005 | 12:17 AM
cr6sid9's Avatar
Default Abnormal noise 1996 vette
My 1996 coupe has an abnormal whirring sound coming from the rear of the casr when making 90 degree or greater corners at any speed. I can not identify exactly where the noise is coming from. Since the problem started, i have replaced the brakes in hopes to fix, but no luck. Any suggestions?
Old Sep 14, 2005 | 12:56 AM
bobbyj's Avatar
Default RE: Abnormal noise 1996 vette
The rear end is most likely the problem.
Go to a GM dealer and purchase the reare end additive that is required for the Corvettes. $10.00-$12.00
Take it to a lube center and have the rear end lube changed and have them add the additive.
The noise is common in the Corvette and this should silence this problem for the most.
Have a good Corvette!!
Old Sep 14, 2005 | 12:57 AM
bobbyj's Avatar
Go to a GM dealer and purchase the rear end additive that is required for the Corvettes. $10.00-$12.00
corvettesrus
Nov 22, 2006 02:06 PM
hsean
Jul 29, 2006 08:24 PM
goesnines
Jun 25, 2006 08:29 PM
malibu1
Aug 7, 2005 11:05 PM
kstrbss111
May 14, 2005 11:22 PM
