C4 fuel injections
Old Aug 5, 2006 | 05:09 PM
jrc316's Avatar
Default C4 fuel injections
Hello, i am ready to get a C4 and i have been researching them but i cannot find where they switched from Tuned Port Injection to a Multi-port injection system.. What Year?? Thanks Russ
Old Aug 6, 2006 | 02:02 AM
LeesVette's Avatar
Default RE: C4 fuel injections
1985 was the last year for Tuned Port Injection.
Old Aug 6, 2006 | 08:57 AM
mypetu39's Avatar
On the front fenders of my 87 Vette is a piece of trim which says, "Tuned Port Injection". Did someone add this trim to the car before I got it ??????
mypetu39
Old Aug 6, 2006 | 09:31 AM
I believe 1990 was the last year for TPI. When the LT1 engine became available, GM used sequential injection, that is each injector fired on the compression stroke.
Old Aug 6, 2006 | 12:52 PM
jrc316's Avatar
well the reason i am making this post is that a friend of mine and i were having an argument that TPI "tuned port injection" was a throttle body injection and he said he had it on an 82 Z-28.
I dont think TPI came out until 84 or 85 on the IROC
I say that Tuned port is NOT a throttle body and has 8 injectors..
At any rate i would like to get my car with a more modern injection system hoping it will be more trouble free.. I am looking to buy a 90 to a 94.. C4 . Russ
Old Aug 6, 2006 | 05:11 PM
shadow87's Avatar
1982 Z28 was cross fire injection which was two throttle bodies not tuned port.
Old Aug 6, 2006 | 11:26 PM
LeesVette's Avatar
Here is where I got my info:
http://www.corvetteactioncenter.com/...5/85specs.html
1985 Corvette Specifications
Dimensions
Wheelbase (in.) 96.2
Track Frt/Rear (in) 59.6 / 60.4
Length (in.) 176.5
Width (in.) 71.0
Height (in.) 46.7
Ground Clearance (in.) (minimum) 5.0
Curb Weight (lbs) 3,224 - Automatic Transmission
3,216 - Manual Transmission
Weight-to-power ratio (lbs:hp) NA
Coefficient of Drag 0.34
Weight Dist. F/R (%) NA
Coolant Capacity (qt.) NA
Fuel Capacity (gal.) 20.0
Oil Capacity (qt.) (without filter) 4.0
Engine Specifications
L98
Type Overhead valve, pushrod V8, 2 valves/cylinder, cast iron block/heads
Bore 4.00 in.
Stroke 3.48 in.
Displacement 350 ci.
Compression Ratio 9.0:1
Horsepower 230 hp @ 4,000 rpm
Torque 330 lb-ft @ 3,200 rpm
Redline (RPM) NA
Induction System Bosch Tuned Port Fuel Injection
Cylinder Block Material cast iron alloy
Cylinder Block Deck Height 9.025"
Cylinder Head Material cast iron alloy
Head Gasket Thickness (compressed) .021"
Total Dressed Engine Weight (dry) 585.7 lb
Note: These weights do not include radiator hoses, coolant, accelerator controls and engine mounting hardware.
Miscellaneous
Brakes
Type NA
Front Rotors (diam) 11.5 in. vacuum assist. vented disk
Rear Rotors (diam) 11.5 in. vacuum assist. vented disk
Wheels and Tires
Wheel Size (Front) 16 x 8.5 in. (RPO Z51: 16 x 9.5 in.)
Wheel Size (Rear) 16 x 8.5 in. (RPO Z51: 16 x 9.5 in.)
Wheel Type 5-bolt, cast alloy
Tire Make/Size Goodyear Eagle VR50, P255/50VR-16
Transmission
Automatic Manual
Type 4-Speed Automatic 4-Spd. Man. Doug Nash
Gear Ratios
1st 3.06 2.88 (1.93 OD)
2nd 1.63 1.91 (1.28 OD)
3rd 1.00 1.33 (0.89 OD)
4th 0.70 1.00 (0.67 OD)
Reverse NA NA
Axle Ratio 2.73 (RPO G92: 3.07) 3.07
http://www.corvetteactioncenter.com/...6/86specs.html
1986 Corvette Specifications
Dimensions
Coupe Convert.
Length (in.) 176.5
Width (in.) 71.0
Height (in.) 46.7 46.6
Ground Clearance (in.) (minimum) 4.7
Curb Weight (lbs) 3280 3266
Weight/Power (lbs/bhp) 15.1 14.4
Coefficient of Drag 0.33 NA
Weight Dist. F/R (%) 51/49 50.2/49.8
Coolant Capacity (qt.) 14.6
Oil Capacity (qt.) 4.5
L98
Type Overhead valve, pushrod V8, 2 valves/cylinder, cast iron block, aluminum heads
Bore 4.00 in
Stroke 3.48 in
Displacement 5.7L / 350 ci.
Compression Ratio 9.5:1
Horsepower 230 hp @ 4000 rpm (235 hp w/ alum. cyl. heads)
Torque 330 lb-ft @ 3200 rpm
Redline (RPM) 5,500
Induction System Bosch Multi-Point Fuel Injection
Miscellaneous
Brakes
Type ABS Power-assist vented discs
Wheels and Tires
Transmission
Automatic Manual
Type 4-Speed 4-Spd. Doug Nash w/ OD
Gear Ratios
Reverse NA NA
Old Aug 7, 2006 | 09:40 AM
ORIGINAL: jrc316
You are right. TPI came out in 1985 and is not a throttle body injection. THrottle body started with cross fire, which was 2 throttle bodies and then GM saw the error of their ways, so to speak, and then started to put 2 injectors in one throttle body, a setup which they used on pickups until early 90's.
Old Aug 7, 2006 | 12:37 PM
jrc316's Avatar
Thanks for that link, i will check it out.. Russ
slayerz06
Feb 10, 2009 10:48 PM
