Making Room for Wider Tires
Old Aug 12, 2005 | 10:33 AM
Cla$$ics's Avatar
Default Making Room for Wider Tires
I want to put some wider rear tires (15/275) on my 62 to accomodate my new ZZ383/425 HP motor. I don't want to cut/tub the wheel wheels but rather go inside by moving the leaf springs over and maybe doing coil over shocks or adding an air suspension system. Anybody have any experience doing this or suggestions on what to do/not do?
Old Aug 12, 2005 | 10:54 AM
Default RE: Making Room for Wider Tires
I would not go with an air suspension. They seem to be too bouncy and not that great for high HP cars like yours. I would start buy moving the wheels as far out as possible. Pick a wheel with an offset that allows you to get as close to the outer fender as possible without rubbing it. This will give you more room to play with on the inside and will give you a little wider stance.
Old Aug 12, 2005 | 08:01 PM
Cla$$ics's Avatar
Thanks Danase - Great advice! I've decided against the air suspension for the reasons you state. Who wants to turn a Vette into a bouncy, floating ride like a Lincoln . . . The coil over shocks will work. However, the wheel offset advice you offer works, but only up to a point . . . those damn leaf springs are still close-in that no amount of offset will allow a fat tire to fit. Looks like I'll have to have the leaf springs moved inward to make room . . or rip out the entire diff and start from scratch with a whole new rear end & suspension. Just trying to save some money, not be too radical and still have some room to squeeze in some P275's or P285's. Again, thanks for your advice . . .
Old Aug 13, 2005 | 07:42 PM
ORIGINAL: Cla$$ics
No problem! Glad I could help a bit. Coilovers are a great way to go for suspension so you can't go wrong there. Keep us informed at how the project is going!
Old Aug 15, 2005 | 11:36 AM
and if you want something that will REALLY boost the cars handling and launching ability, look into CalTracs.
Old Aug 29, 2005 | 10:33 PM
V6DVette's Avatar
Just signed up to add a little info here.
No way will you get 275s under unless you move the inner fender wells in about 2". I didn't want to tub mine either and oppted to do just that. Along with the 4 link.[ I hated the idea of having the tire hang out past the fender. I only have an old set of G60s to test fit but theres plenty of room now.
[IMG]local://upfiles/617/FF3BCA9B922947858BE29696F26F1193.jpg[/IMG]
Old Sep 22, 2006 | 10:46 PM
Custom63's Avatar
I am runnin a 295/50H/15 ! With moddification of course..but not tubbed.
http://i9.tinypic.com/30sv86d.jpg
Chris
Ted
Jun 29, 2012 07:34 PM
iresolver
Sep 8, 2007 10:10 PM
batesy80
Aug 30, 2007 07:42 PM
blueshark
Jan 23, 2007 03:54 PM
