Gear Ratio???
Old Apr 10, 2007 | 01:26 PM
OldSchool72's Avatar
Default Gear Ratio???
I'm trying to figure out what rear differential is in my '72 without counting the teeth. I run 65 mph @ 3100rpm's on the highway. Anyone want to give me an estimate??? The trans is a TH400.
Thanks in advance,
Craig
Old Apr 10, 2007 | 03:40 PM
Default RE: Gear Ratio???
Depends on tire size. I'm guessing you have a 3.55 rearend.
Here's the formula if you don't want to jack up the rearend and count the driveshaft revs per wheel revs.
Rear ratio = (2.98 times tire outer diameter in inches) divided by miles/hour per 1,000 rpm
This should get you close enuf that you can tell what the actual ratio is.
Old Apr 10, 2007 | 03:55 PM
Thanks, I'll look at what size they are tonight. I know that they are bigger than stock tires (Goodyear Eagle GT II's) as my speedo says 10mph faster than I'm actually going. I took a handheld gps with me and 76 on the speedo was 75 on the gps.
Old Apr 10, 2007 | 05:38 PM
I've got 255-60X15 Eagle GTs and a 3:55. I get 22 mph per 1,000 rpm in 4th.
Old Apr 11, 2007 | 09:36 AM
ORIGINAL: OldSchool72
Ooops...Typo in my previous post. It's was actually 65 on the gps and 76 on the speedo. Thanks for your input!
Old Apr 20, 2007 | 12:40 PM
ORIGINAL: 73shark
Thanks, my tires are 255/60/15's as well. I wonder if the ratio of a turbo400 in third is the same as a four-speed car in 4th?? If they are the same....then my rear is 3:55. [sm=gears.gif]
Old Apr 20, 2007 | 07:23 PM
SCHOON's Avatar
If you come off the line pretty good you probabbly have a 3:55.
If you bog a bit then figure on a 3:36
If you engine is screaming at 55MPH figure on 3:73 or so on.
Old Apr 21, 2007 | 01:07 AM
Both transmissions are 1.00 to 1, so yes, you do have 3.55 gears.
Old Apr 24, 2007 | 12:35 AM
76sting's Avatar
I would say your close to 3.50
Old Apr 25, 2007 | 09:32 AM
ORIGINAL: 73shark
Thanks alot!! Does anyone know if the 3.55 gears were standard or an option?
