tires for my C5
Old Jun 5, 2005 | 10:17 AM
Sandy2525's Avatar
Default tires for my C5
I am thinking about buying new tires for my 98 C5 - I currently have Goodyear run flats - any suggestions on a good replacement tire that are not so expensive ?
Old Jun 5, 2005 | 12:42 PM
Default RE: tires for my C5
i did some poking around, and here is what i came up with:
Kumho ECSTA MX
that would be around 660 for all four, plus shipping, which was abut 10 bucks a piece for 204-40zr17s..i dont know where you live, but to have them shipped to detroit would cost 33 bucks. so youd get all 4 tires for under 700 bucks. I have used kumho, and while they are certainly no BFG or goodyear, theyre a pretty good tire, especially for the price.
Old Jun 17, 2005 | 04:11 PM
gorillavette's Avatar
Sandy, try tire rack (tirerack.com) for the best prices and selection. They ship to your installer or will give you an installer in your area. I just purchased a set of Goodrich G force KDW 2's for a little over 600 bucks with shipping. I had them in 2 days! Excellent tires for non-runflats. If you have to have run flats they have those as well.
Old Jun 29, 2005 | 11:35 AM
bmwdiver's Avatar
I'd have to agree with Patrick, i've been running with the Kumho's for several years now, and am completely satified with there performance and driveability. that and there much cheaper than the factory goodyears. [sm=americanasmiley.gif]
Old Jun 29, 2005 | 04:39 PM
the problem is that people assume that goodyear=good and cheap=bad
i wouldnt have goodyears if they were FREE. [:'(]
Old Feb 2, 2006 | 03:34 PM
jjvette00's Avatar
hey sandy, i am selling a set of 4 stock run flats, check out my forum on here in the classifieds, i can save you a nice penny email me if interested.
Old Feb 16, 2006 | 12:32 AM
...then check a recent edition of Car & Driver. Although they used "only" a 325 BMW as a test mule, you are very likely to experience similar results with your C5. To minimize variables such as driving techniques, track surface temps, etc, C&D enlisted the help of the Tire Rack and their test mule vehicle. Although the track used was small, it's lined with sprinklers that can soak the asphalt. "It took three days to perform all the tests. We accerated to 50 mph and then braked to a standstill. There was a benefit to that lower speed: It ensured that we were measuring the braking performance of the tires and not just brake fade."
"In addition to factoring the wet and dry scores, we gave points based on a tires's price and tread-wear grade, which is a rough estimate of how long a tire will have usable tread." "Our test focused on measuring performance, so we decided that results in the dry-lateral grip, for example - would carry the most weight."
So, without further adeau, here're the results:
(Best to worst):
NUMBER 1: Goodyear GSD3: "As an all-around performance tire, you can't beat this Goodyear. It was the best performer in all three wet-track tests and was very competent in the dry. It generated .94g on the dry skidpad, only .01g off the first place (dry) BFGoodrich and tied with the Yokohama and Hankook.
The Goodyear gripped so well, that you might not have been certain that the road was wet. It held onto the wet track with .82g of stick, an impressive figure considering the worst tire in that test made only .67g.
...And like the Continental, the Goodyear had a high 280 trad-wear grade. At $145, ieach, it's $34 cheaper than the most expensive (guess which tires have THAT distinction!).
2nd place: Continental ContiSportContact 2: "It simply didn't feel as sporty as the others.....on dry surfaces, the Conti never rose above third from last among 11 tires. It felt soft and imprecise. But in the wet, the spread from best to worse was 15 percent, which made for a larger point spread (giving the Contis a boost). Plus the Continental had a 280tread-wear grade that was the highest (tied) for this test.
3rd place: Yokohama Advan Neova AD07: Excellent dry performance, but a bit on the slippery end in the wet stuff - expensive at $175 apiece.
4th place: Michelin Pilot Sport PS2: "At $179, the PS2 is the most expensive tire in the test." Competent, but expensive sums up this tire.
5th place: Hankook Ventus R-S2 Z212: At $99 each, these are the least expensive tires - very good on dry pavement, but "greasy and slow to recover" on the wet stuff.
6th place: Dunlop SP Sport Max: "In the dry, the tire seemed to lose its confidence..."
7th place: Pirelli P Zero Rosso Asimmetrico:"In the dry-lateral-grip test, the Pirelli tied for second to last, and it finished seventh in the dry-braking test.
8th place: Toyo Proxes T1R: "...the Proxes never placed higher than eighth in any test"...nuff said!
9th place: Bridgestone Potenza RE050A: "it felt dull and disconnected and was somewhat soft and imprecise when driven hard."
10th place: BFGoodrich g-Force T/A KD: Outstanding performance on dry surfaces, but very scary on wet surfaces - don't get caught in a rainstorm wearing these shoes...
11th place: Kumho Ecsta MX: "They didn't offer much grip and the time of 30.28 seconds in the dry autocross was .62 second slower than the fastest tire. That may not seem like much, but our course was only 0.3 mille long, and on a longer track, that gap would be commensurately greater." "And although the MX - at $136 per - was the third-least-expensive tire in our test, the high score in the price category wasn't enough to regain ground lost in the performance tests."
On a congratulatory note, the first place tire is made right here in the USA by an American tire company!
Old Mar 31, 2006 | 06:45 PM
evo's Avatar
evo
I took the run flats off .i could have run a super swaper mudders and run smother. as far as the 17/18 stager to me it a big joke .after 2 month of looking for the right wheel and tire combo. there was a lot of fighting with the local tire and wheel stores. the net was even worse. i went to the guys that always helped me with my pro street projects WELD WHEELS. these guys are the bomb .talked to the tech and got more info in 5 min than 2 months of sale men BS.i drive my vet evey day back and forth to work about 120 miles.so keeping the tires rotated is a must.the large wheel look of 20s was what i wanted but 20s will rub on front and being that 20s can only be 255/20 way to narrow . so the is the set that i went with was weld evo [andro 5] 19 x 9 1/2 with 285/30/19 toyo t1r all the way around.
Old Apr 1, 2006 | 10:54 AM
That is a good solution given your driving and need to rotate tires, and those wheels look pretty good. I'm curious if you notice any strange handling characteristics given that you have similar size tires and wheels front and back (my point being the car is set up for wider rubber at the rear so I would expect it to oversteer a bit more now).
Toyo T1Rs tend to wear rather quickly from what I hear. One thing to look at it the wear starts getting expensive is Hankook - they are nearly as good as Kumos but really inexpensive and wear quite well -- I had a set on my Audi S4 for a while and I'd guess they would go 60K miles a set.
Old Apr 1, 2006 | 04:15 PM
corvette king's Avatar
if you live near a pep boys they have z rated tires i have them on my vette, they are a good tire, they hook up, they handle great, z rated .smooth ride.and only cost 98.00 bucks a piece, cant beat that,every body thinks name brand name brand.well today all these tire companies are just living off there name. so brand really doesent matter any more.
[IMG]local://upfiles/1664/4F4E0E7C1FFA40C6A9281106E6C4E131.jpg[/IMG]
