Go Back   Corvette Forums - Corvette Enthusiast Site > Corvette Models > Corvette C1 & Corvette C2
Sign in using an external account
Register Forgot Password?
Search
Old 07-07-2008, 06:20 PM
reeltales reeltales is offline
Default 1967 Gas Tank Removal
I have just bought a 67 convertable. I need to replace the fuel tank. Can this be removed without removing the body?
Old 07-07-2008, 08:16 PM
78buckshot 78buckshot is offline
Default RE: 1967 Gas Tank Removal
Welcome to the best Vette forum reeltales, I can't say for certain on the mid-year cars if you can drop the tank, I assume you can. Mine is a '78 and like all of the C3's, the tank comes out from the bottom. Please be patient, someone here will give you the answer.
Old 07-07-2008, 08:20 PM
Oh yah, I'd like to add that the frame and most of the rolling stock is the same from 1963 thru 1982, so I don't think the gas tank mounting will be any different in those years.
Old 07-08-2008, 05:52 AM
I have removed the crossmember that is below the tank and taken the nuts off of the tank straps. The tank will move around but appears to be too tight to just drop out the bottom. I do not want to try to force it out until I know for sure it will come out. There may be a trick to getting it out.
Old 09-12-2008, 09:45 PM
LT1driver LT1driver is offline
you remove straps holding tank and then you have to tilt up the end (toward front of car I think) and wiggle it out, it seems impossible but it WILL come out, done it several times on my 67 and in fact plan to do it soon. good luck.
Old 09-16-2008, 08:11 PM
I was able to remove the tank. Now to order a new one. Despite the 14 year old gas that was left in the filter and lines, I was able to get the car running with the help of a new distributor.
Tags
1965, 1966, 1967, 65, 67, c2, corvette, drop, gas, install, photos, removal, remove, replace, tank
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Our Sponsors
Internet Brands, Inc.
