Brand NEW product from Pinnacle Wax - Exhaust Cleaner & Brightener
Pinnacle Exhaust Cleaner & Brightener
https://cimg9.ibsrv.net/gimg/www.jag...5ccddb947c.jpg Cleans to remove stubborn dirt and soot, polishes to a mirror finish, and coats for long lasting protection As the owner of Pinnacle Natural Brilliance, people expect my car collection to be cleaner and shinier than anyone else’s. Of course I’m going to be a bit biased, but that assumption is spot on. Here’s my secret: don’t overlook the small details! I go to car shows all over the world, and the recurring issue that I see over and over again is dirty exhaust tips covered in soot, road grime, oil, and grease. I have a solution, and it’s called Pinnacle Exhaust Cleaner & Brightener. Having swirl-free paint means nothing if your glass isn’t streak-free, tires aren’t perfectly dressed, and exhaust tips aren’t polished to a mirror shine. Up until this point, Pinnacle Natural Brilliance had you covered for all of the above, except exhaust cleaning and polishing. Frankly, I was embarrassed being seen using other company’s metal polishes to clean my exhaust (and they didn’t even work that well to boot), so I assigned my best chemist to develop a cutting-edge metal polish designed specifically for the cleaning needs of exhausts. Pinnacle Exhaust Cleaner & Brightener is a thick cream that is formulated using an advanced blend of all-natural cleaners, diatomaceous clay, and a durable anti-corrosion agent that protects the surface against heat and soot build up. Pinnacle Exhaust Cleaner & Brightener is not the least bit messy to use, and it’s easy enough that anyone can polish their exhaust tips to a mirror finish in just a few minutes. The exhaust system on your vehicle functions to guide reaction exhaust away from a controlled combustion inside the engine and includes one or more exhaust pipes. Unburned oil and gas causes a build up of black soot on the exhaust tip, creating an unsightly appearance that draws attention away from the paint you spent hours polishing. Remove the exhaust soot and polish your tips to a mirror finish with Pinnacle Exhaust Cleaner & Brightener. Like other car care products that bear the Pinnacle Natural Brilliance name, Exhaust Cleaner & Brightener is an all-natural formula that doesn’t contain any caustic chemicals that are harmful to you or the environment. The first time you crack the lid you’ll be pleasantly surprised at the beachy fragrance of Pinnacle Exhaust Cleaner & Brightener. When could that ever be said about a metal polish?! https://cimg4.ibsrv.net/gimg/www.jag...156c2b7598.jpg Use Pinnacle Exhaust Cleaner & Brightener on polished, chrome and bare metal surfaces. Don’t stop at the exhaust tip! If you have a polished muffler, Pinnacle Exhaust Cleaner & Brightener will make it shine like a mirror. For best results, apply it using a Lake Country Exhaust Polishing Sponge. https://cimg6.ibsrv.net/gimg/www.jag...973c5b3c19.jpg https://cimg9.ibsrv.net/gimg/www.jag...911f13e562.jpg https://cimg0.ibsrv.net/gimg/www.jag...f52298a54e.jpg CLICK HERE to get your Pinnacle Exhaust Cleaner & Brightener |
