How To Clean Wheels With Ease
PINNACLE CLEAR COAT SAFE WHEEL CLEANER - DAYTONA SPEED MASTER BRUSH
http://www.jaguarforums.com/forum/at...ine=1381858768 The Pinnacle Cleat Coat Safe Wheel Cleaner can safely be used on all types of wheels including painted, clear coated, polished, anodized and even chrome. It is designed to penetrate even the most stubborn dirt and grime instantaneously on contact. It has been formulated to specifically target the contaminants on the wheel surface such as tar, brake dust, oil and grease and remove them without jeopardizing the finish of the wheel in any way. BEFORE http://www.jaguarforums.com/forum/at...ine=1381858768 Brake dust, road grime, and dirt http://www.jaguarforums.com/forum/at...ine=1381858768 The product should be sprayed onto the surface of the wheel and be lightly agitated with a soft bristled detailing brush (Daytona Speed Master Wheel Brush) before being thoroughly rinsed off. The agitation step may not always be required especially if your wheels are only lightly soiled but it does helps top break the bond between the wheel surface and the contaminants prior to rinsing. http://www.jaguarforums.com/forum/at...ine=1381858768 http://www.jaguarforums.com/forum/at...ine=1381858768 AFTER http://www.jaguarforums.com/forum/at...ine=1381858768 It only took me about 10 minutes total to clean all 4 wheels. The wheels were just caked with brake dust and road grime and the cleaner just removed it with ease. I scrubbed very lightly with the Daytona Speed Master Brush. Hardly any effort went into this and the results came out fantastic:D. Thanks |
