How To Properly Clean Your Interior
http://www.autogeekonline.net/galler..._175420278.jpg
This is the Pinnacle Concours Interior Kit and I am using it on the leather seats below. I used this kit because it has everything you need for your interior. There are really only 3 steps to this kit and it doesn't take long to do. First step is to clean the leather and vinyl, then condition the leather, and finally condition the vinyl and rubber. Very simple to use and the results are amazing. The Pinnacle Leather & Vinyl Cleaner has natural citrus cleaners that lift out grease, oils, and dirt. It also has a fresh lemon scent that smells really good. The cleaner really got in there and removed all the grime and dirt that was in the leather. Dirt And Grime Buildup http://www.autogeekonline.net/galler.../IMG_26831.JPG http://www.autogeekonline.net/galler.../IMG_26982.JPG Use The Wood Grip Scrub Brush To Remove Deep Down Dirt And Stains http://www.autogeekonline.net/galler.../IMG_27022.JPG Clean The Vinyl With A Microfiber Applicator http://www.autogeekonline.net/galler.../IMG_27041.JPG Next is the Pinnacle Leather Conditioner. The conditioner nourishes the leather with a rich formula of lanolin and natural oils. Pinnacle Leather Conditioner contains a really strong UV protectant but also leaves your leather feeling soft and supple. http://www.autogeekonline.net/galler.../IMG_27081.JPG Applying Leather Conditioner http://www.autogeekonline.net/galler.../IMG_27101.JPG And the last step with this kit is the Pinnacle Vinyl & Rubber Protectant. This will beautify and protect your car's dash, vinyl seats and door facings against premature aging. It gives you a non-greasy satin finish that won’t glare when the sun hits it. The dash came out looking great as you can see…. Applying Vinyl & Rubber Protectant http://www.autogeekonline.net/galler.../IMG_27282.JPG And The End Results http://www.autogeekonline.net/galler...731_-_Copy.JPG http://www.autogeekonline.net/galler.../IMG_27291.JPG Overall this kit is absolutely amazing. As you can see, the process is very simple and makes the interior look brand new in 3 easy steps. Thanks for looking |
