Pinnacle Black Label Diamond Paint Sealant
Shines like a diamond! Pinnacle Black Label Diamond Paint Sealant is a resin-based polymer sealant that creates an extremely glossy, slick surface that protects your vehicle’s paintwork against UV rays, infrared radiation, and environmental contaminants. Designed with the perfectionist in mind, Diamond Paint Sealant imparts the type of gloss and reflection that used to be reserved for high-end carnauba paste waxes, without the annoying dust attraction. Formulated for ease of application, Diamond Paint Sealant goes on thin and buffs off with virtually no effort. Black Label Diamond Paint Sealant is unlike any synthetic paint sealant currently available. The chemists at Pinnacle managed to create an entirely new polymer that features an advanced resin as the base. This resin base causes the synthetic polymer to cure faster, shine better, and more importantly, last longer! Multiply this by thousands – the amount of cross linking polymer strands in Diamond Paint Sealant – and you have a polymer sealant that creates breathtaking reflections that last up to 12 months! With Black Label Diamond Paint Sealant, there are no compromises. Not only will Diamond Paint Sealant create crisp, clear reflections on light colors and a fluid, liquid gloss on dark colors, it leaves your paint feeling smooth and slick for extended periods of time. Month after month, wash after wash, your vehicle’s paint will feel like you just applied Diamond Paint Coating. Your vehicle’s clear coat contains UV inhibitors, which protect it against sun-induced fading and discoloration. These UV inhibitors, while very effective, only have a half life of 5 years. That means 5 years after your vehicle is brand new, nearly all the protection in the clear coat is depleted. By simply applying Black Label Diamond Paint Sealant once a year, you ensure that the UV inhibitors stay put so your paint doesn’t fade, discolor, or oxidize. Black Label Diamond Paint Sealant protects your paint against more than UV rays. Thanks to the durable, cross-linking bond that Diamond Paint Sealant creates, your paint will be shielded against acid rain, industrial fallout, bird droppings, and more! The immense amount of surface tension created by Diamond Paint Sealant causes water to bead up and roll off, taking dirt and grime with it. Your vehicle will stay cleaner in between regular washes! Maintain the exceptional shine and long lasting protection of Diamond Paint Sealant with Black Label Diamond Coating Shampoo. This hyper-concentrated shampoo features a new generation of TUF SUDS technology that creates mounds of thick, frothy suds. Regularly washing your vehicle with Diamond Coating Shampoo ensures the impressive water beading and slick nature of the sealant remain intact. http://www.pinnaclewax.com/lib/autogeek/bl-ps-1.jpg http://www.pinnaclewax.com/lib/autogeek/bl-ps-2.jpg Directions: 1. Shake well before using. 2. Ensure surface is cool to the touch and out of direct sunlight. 3. Clay and polish surface if necessary. 4. Apply by hand or machine using a soft foam applicator pad. 5. Let product dry to a haze (5-10 minutes) and buff off residue with a Gold Plush Microfiber Towel. http://www.pinnaclewax.com/lib/autog...stingray-1.jpg 1966 Stingray detailed with Black Label Diamond Coating Shampoo and Black Label Diamond Paint Sealant. The only thing more impressive than the shine is the pavement-wrinkling torque created by the big block! |
