Polishing Your Car with Pinnacle Car Care
Pinnacle Advanced Finishing Polish is packed with diminishing abrasives that maximize surface gloss and reflectivity on all paint finishes. Our unique abrasives break down gradually as they scour the finish, blending away any haze and restoring perfect clarity to the paint.
Pinnacle Advanced Finishing Polish is a combination of diminishing abrasives and lubricants that buffer the abrasive action. The lubricants nourish and enrich the paint, while allowing the abrasives to move over the paint fluidly. Minor imperfections and cloudiness will disappear, revealing a crisp, clear gloss. Products Used: Pinnacle Advanced Finishing Polish Lake Country 6.5 inch CCS Pad Flex XC3401 VRG Orbital Polisher (Dual Action) Gold Plush Jr. Microfiber Towels http://www.autogeekonline.net/galler...4/IMG_2800.JPG Machine Application: 1. The vehicle should be clean and dry before polishing. Always wash your vehicle before polishing to remove any loose dirt and debris. 2. Pour a quarter-size amount of Pinnacle Advanced Finishing Polish onto an orange light cutting pad or white polishing pad. You may also apply the polish directly to the vehicle or in a circle on the pad. Spread the polish over the area you intend to polish with the machine turned off. This will reduce splatter. 3. Set the maximum speed on the polisher to 4 or 5. Set the pad on the paint and turn it on. Work in a side to side, then up and down motion until the polish starts to dry, 4. Make sure the polisher is off before lifting it off the paint. Buff with a microfiber towel to inspect your results. If swirls are still visible, repeat the process or step up to Pinnacle Advanced Swirl Remover. WATER SPOT CLOSE UP http://www.autogeekonline.net/galler.../IMG_28052.JPG BEFORE – TAPE LINE http://www.autogeekonline.net/galler.../IMG_28084.JPG AFTER http://www.autogeekonline.net/galler.../IMG_28162.JPG http://www.autogeekonline.net/galler.../IMG_28213.JPG END RESULT - WITHOUT WAX http://www.autogeekonline.net/galler.../IMG_28285.JPG Overall, you can see how great this polish finishes. Pinnacle Advanced Finishing Polish gives your vehicle’s paint maximum impact with a clear, reflective gloss and flawless appearance :icon_smile: |
