1963 corvette
http://s3.racingjunk.com/ui/6/48/363...3-corvette.jpg
Engine 712 cid Donavan HC 700 block Lunati crank 5.300 stroke Crower titanium rods Venolia pistons Sonny's 14.5 deg heads T & D shaft rockers Sonny's camshaft Sonny's sheet manifold Split dominators Msd front drive dist Moroso dry sump system Moroso vacuum pump Ati balancer Mezier water pump Davis rad and shroud Magnafuel pump/filter Stroud diaper Oil and water heaters Custom headers Trans Coan COA-21160 lightweight turbo 400 Coan 10 inch bolt together converter CSR carbon fiber sfi shield Precision performance 3spd shifter Co2 air shifted Dig delay Trans shift controller Earl's Trans cooler Chassis/suspension Fuller race cars cm double frame rail 6.0 25.1E cert to 12/15 Powder coat black and clear Lamb double adjustable struts Lamb front brakes Pro box rack and pinion Fab 9 inch rear Avenger 4-link Anti roll bar Dual engine limiters ... $80,000 Posted by: djl634 Location: HAGERMAN, ID Post Date: November 16, 2014 Expires: February 8, 2015 More... |
