1964 Chevrolet Corvette
https://s3.racingjunk.com/ui/7/48/30986487-508.jpg
PRICED REDUCED Above Added: Wed July 10, 2013, 11:11 am EST 1964 CORVETTE 4 SPEED, TOTALLY OFF FRAME RESTORATION, FACTORY IGNITION KEY THAT WORK THE DOOR LOCKS AS WELL. FACTORY NUMBERS MATCHING 327 ENGINE BUT TOTALLY UPDATE ON REBUILT WE USED BRAND NEW EAGLE RODS THE STEEL CRANK WAS MAGNAFLOW BALANCE ,THE MAIN BOLTS WERE REPLACE WITH ARP STUDS THE ENGINE WAS BORE TO A 030 OVER WITH NEW TRW 10 TO ONE COMPRESSION WE ALSO HAVE A CAMSHAFT REGROUND TO THE 365 H.P. FACTORY DUNTOF 30-30 SOLID CAM AND WE ALSO USE A NEW SET OF ALUMINUM HEADS WITH 205 SUPER DUTY STAINLESS INTAKE VALVES ,ALSO HARDLAND SHARP ROLLER ROCKERS AND WE CUSTOM MADE THE INTAKE TO FIT THE HEIGHT RUNNERS ON THE HEADS AND THE 3... $75,000 Posted by: pandiracing064 Location: TAMPA, FL Post Date: October 21, 2017 Expires: January 13, 2018 More... |
