1972 Chevrolet Nova
http://s3.racingjunk.com/ui/7/30/32037307-082.jpg
This Nova has undergone a very extensive, tedious, and costly restoration (over 35k invested to date). Every piece of bad sheet metal was cut away and replaced with brand new replacement panels. All of this work was done professionally and the entire Nova is completely straight. The paint & body work were also done professionally. The paint is phenomonal and I guarantee that it is destined to win some awards. It is called Shandough Sunset by Dupont and as you will see, it is absolutely gorgeous. The 355 motor within the Nova was just installed and has less than a hundred miles on it. It was built by Vamp Racing and it was built to push you in to your seat. It is what makes this Nova so remarkable. The transmission & rear end were also rebuilt and also have less than a hundred miles on them since being installed. All of the components on this Nova are also new. The power disc brakes and power steering, both are brand new and work exceptionally well. Body: The body on this Nova is completely straight and free of rust. Every piece of bad sheet metal was replaced with brand new replacement panels. Located at the very bottom of this auction you will find a bulk of photos detailing the restoration of the body. The Nova r... $14,900 Posted by: shawnmid Location: INDEPENDENCE, MO Post Date: October 3, 2013 Expires: December 26, 2013 More... |
