Corvette Z06
http://s3.racingjunk.com/ui/6/15/430...rvette-Z06.jpg
More Pictures in the other post in this catagory.this post has more thorough list Above Added: Tue November 1, 2016, 3:00 pm EST Corvette Z06 GT Chassis-- Corvette Z06 aluminum chassis with 8 point steel cage bonded/bolted from front to rear control assemblies, bolt on replacable rear re bar, airfoil uprights connected to main frame rails (prevents airfoil damage in rear contact) car weighs 2800lbs Engine-- 20 hrs on LS3 with LS9 heads and Comp trinion kit, GM LSA cam, Callies forged crank, Mahle piston, Daily 5 stage dry sump and billet pan, ATI Damper, Peterson tank w/preheater and primer, BMRS lines, Griffen radiator w\Spal fan, LG headers and x pipe into rear exit all welded 3" w/quick clamps, LG heat shields GMPP ecu and harness, AIM EVO 4 datalogger w/gps,... $57,000 Posted by: everatt Location: Scarborough Post Date: October 27, 2016 Expires: February 16, 2017 More... |
