Mopar SHORT BLOCKS. Big BLOCK R/B , 465, 500 !!!!
https://s3.racingjunk.com/ui/6/29/50...OCK-RB-465.jpg
SHORT BLOCK, R/B, This shortblock can not be used with Indy 572-13 heads!!! or B-1 Heads Mopar, 465 R/B Shortblock, 440 Block 10.715 (Stock Block) ARAIS Pistons .090 Dome +6 cc, 4.350 Bore, .990 Pins, EAGLE H-BEAM Rods 7,100 ARP L-19 bolts, OHIO Crankshaft 4340 3.900 crankshaft,2.200 Journal, balanced, STD/STD, King Narrowed rod bearings, And KING Main Bearings, TOTAL SEAL conventional Rings, Block cleaned, decked, ARP Main studs installed, Align Honed, bored and honed with plates, Cam bearings installed, Dist. bushing installed. Will disassemble for buyer inspection. PISTONS have been run, New Rods, and New crankshaft, Fresh block, Will not ship: if you can't inspect it and pick it up, this is not for you. 1972 casting block Compr... Posted by: DAYTONA540 Location: CLARKSVILLE, TN Post Date: November 15, 2017 Expires: November 22, 2017 More... |
