64 ammeter guage
my ammeter gauge is all over the place but always on the 0-40 plus side...multimeter shows a steady 14.40 charge rate. Is this spring loaded or what..its spastic?????
RE: 64 ammeter guage
Check your connections. Intermittent jumping of the needle can be caused by a loose connection. |
thanx but all connections are good..Is the gauge loaded like with a clock type spring because I had a bad short in dash wiring and the needle stuck for a couple of days at -40.
when it finally moved it has never been the same... thanx again, stroker |
