Blowing fuses
My 66 is blowing fuse controlling brake/tail/dash lights. Suspect bad ground. Where are the grounds found or any other suggestions welcome. Seems to be motion sensitive where a bump will trip it. Help!! My first forum here, Thanks.
RE: Blowing fuses
Check the wiring in your trunk.
Sometimes after years of rubbing on the wires become exposed and touch metal causing the fuses to blow. |
