engine heating problems
I have a '65 Roadster with a 300 hp small block and auto transmission. In warm weather, like summertime, the engine temp runs 200 to 210 degrees. I can't make myself believe that this is design temp for the engine. I have a stock radiator that I have had out of the car and cleaned and boiled out. The water pump seems to be doing its thing and I have a new fan clutch. It has a 190 degree thermostat in it. Is there a coolant that will help with the engine temp? I want to keep the car stock so an aluminum radiator would be like a last resort. I would appreciate any info available. Thanks for the reply. John
RE: engine heating problems
hi john,try redline water wetter,it will drop temp 20 deg,and try a 180 thermostat,that should help.and make shure your cap is in good shape,and you have no air in system.:D
[IMG]local://upfiles/1664/39A52A87EC2F40CB97244254C59AA5B6.jpg[/IMG] [IMG]local://upfiles/1664/CFACFAE031514E969A472FA041E06B17.jpg[/IMG] |
In the 60's, they did not run that hot of thermostat. 200 degrees with a 190 degree thermostat is not uncommon. I would change to a 160 degree stat, make sure there is good airflow to your radiator and try the wetter chemical. [8D]
Hey, Thanks for the comment. Can you tell me about the Wetter Fluid? Wherre can I find it? Thanks John
Thanks for the reply. Where can I get the coolant? I really appreciate the information. John
