powerglide leaking late
Hello corvette forums.heres my problem,I have a 67 corvette conv. w/ the factory 2 speed powerglide.the car has completely retro restored to MY specs.and taste.multiple super chevy award winner for best corvette in show as well as best in class.I am very picky when it comes to my car.Anyway...The car runs and performs perfectly w/ the exception of the powerglide.It also runs great except after running for even a little while and shutting it down,it leaks trans fluid on my garage floor after the 2nd. day of shut down a spot about 4" circle directly under the drivers side front corner of the drain pan.I had it totally rebuilt professionally about 1 year ago by the owner of a local transmission shop who also owns top shelf musclecars.(show condition).I have not contacted him yet on this,thought I would ask all of you first to get opinions before I called.
leak
If its leaking around the shift shaft, I have a great solution
Tranny leak at shift shaft.
Originally Posted by Rick Rain
(Post 74473)
wjat is your great solution? |
Muscle Car and Ballroom: Welcome to the forum.
My 66 Powerglide had a big leak out the back. Well I tore the car apart and ordered several different brands
of rear seals to put in. I used the one that looked the best by my eyesight. I also used a sealant around the flange. I haven't finished the car yet. Have several months to go on it. But I hope this does the trick. Good luck. Butch Jersey shore |
