prts 4 U
I want to add power steering to my 63,and it needs some frame repair,should I get new frame?or consider trading it off.
RE: prts 4 U
What type of frame repair are you needing?
Pics would help us, help you. ;) |
RE: prts 4 U
Is the frame repair going to cost more than the car is worth? Or should I say, more than the car is worth to you? You can do all kinds of things with frames. You can even get "front clips" and use everything from a modelthe options you desire and put it on a desired vehicle. Modern front clips are used on old pick-ups all the time. Any frame repair is possible. You only need access to a "framejig, and/or frame straightener if needed. It all depends upon whether or not you want to do the work, or whatever it takes. I always feel that the more you do to your car, the more the car is really "you."
