454 HO crate engine
I just purchased a 454HO crate engine, Gen VI block, for my 71 vette. Its a 4 speed trans. I noticed that there is no place to put the ball stud for the clutch linkage. Does anyone make a bracket to bolt to the block or has anyone made there own to solve this problem?
Thanks, Jeff |
RE: 454 HO crate engine
May have to make the conversion to hydraulic master and slave cylinder, since the later models used that setup.[8D]
Yeah, I think it is assumed that you will go to a hydraulic clutch with the newer crate engines. It is not that difficult a conversion and it is actually a much better clutch linkage, too.
Thanks for the replies. Does anyone make a kit or what vehicle system fits and works the best?
I did a search on Google and came up several options. Try it. [8D]
