Build dates
Old 09-30-2017, 09:43 AM
Steve1968's Avatar
Default Build dates
I have a 1968 vette . The engine build date is june 7th, Would a rochester carb dated june 13th work with this motor? The build date on this car is june 20th.
Also the car has power steering and A/C . The engine code is V0607HT. It says in the book that it should have a HP if it has these options. This motor has never been changed. Is this correct.
thanks,
Steve
Old 10-01-2017, 06:20 PM
Not positive but I think the carb would be OK as don't believe they were part of the engine build. Don't know about the engine code. What book are you referring to? Also might check w/ someone in the NCRS who has access to the judging manual.
