auto to 4 or 5 speed
i am wanting to change from an auto trans to a 4 or 5 speed how hard will this be in my 73, can anyone tell me where to find a clutch brake pedal set
RE: auto to 4 or 5 speed
Hi 73coupe, there is a manual transmission change over kit (PE30) offered by www.volvette.com
Then you'll need a bellhousing. A flywheel A clutch, pressure plate and throw out bearing. You may have to shorten the drive shaft youll need a shifter and linkage and a new shifter plate for the console. And the transmission. Have fun, PG |
