brakes
brakes
On my 1974 vette the brake pedal goes to the floor and barely stops the car, the brake light stays on. The master cylinder is full of fluid. There are no leaks on the floor. What could be wrong? Any help is greatly appreciated. Thanks
I'll check to see if there is any pitting and if not kits are available from MidAmerica Motorworks. Thank you for your help. I will let you know what the results are when I fix the problem. Thanks again!
